Discovered Molybdenum disulfide back around late 60's/early 70's
while designing military/NASA stuff. Spec'ed out for all things, even
as the 'dry lube' (you know it's 'out there' when spec says zero
gravity). Tungsten disulfide is another, newer, dry lube that 'coats',
not plate. Tungsten is easily scraped off, while molyb is 'plated' to
the metal.
Asked one of the physicists and he had to look it up to confirm his
memory. EXTREMELY expensive back then and some times couldn't
get it, so used our military priority POs...of course only for govmnt
use....but one must have lots of stock, right ?
Tungsten is tough to get onto ICE innards, while Molybdenum can
be added to engine oil. It is a solid and needs to either be extremely
fine in particle size, or in a liquid form. Molybdenum naturally bonds
to metal. Molyb is a tougher coating than Tungsten. I had Speeder
research one supplier out in his neck of the woods. Have some potentially
patentable usages for that stuff. The stuff I bought is made to around
2 microns or less in size. 'BEST' engine oil filters down to around 5-7 microns,
IIRC.
Molyb is what makes front wheel drive CV's last so long. In the early
days, they died much sooner.
You shooters out there know all about Molyb both for the slugs and barrels
I've seen small, high rev'ing ICE's temp gauage drop 5*-7* F after just
adding molyb additive. In only 10-12 miles. V8's don't show as much
as there are more things going on and the lessened friction lost in the
noise.
Since plated, losing liquid/grease lube will have it go metal to metal,
but molyb on molyb, which is extremely low friction. Gouging is what
you don't want (welding of the metals).
The place I used to buy from was in Calif and they went out of biz.
Father died (inventor), Daughter ran it for a while, then her brother
who then decided seminary school, so she got it back, but didn't want
to, so tried to sell it off. Very preditory folks tried and failed to buy
it, so she shut it down. I bought hundreds of bucks worth and is my
life time supply, which isn't going to make it...good thing that I'm
living longer than expected...
Only need about 8oz per 5 quarts of engine oil. I used 16oz for my
7.4L after breaking it in.
Haven't looked for a new supplier, but now that you have reminded
me...gotta add that to the list that is way toooooooo looooooooong...
Careful and make sure to check their claimed particle size. If it's
bigger than 5-7 microns, it will get filtered out. Why some have formulated
liquid and when I looked at them, too early and some problems with
acidic reactions of some sort (didn't go any further to investigate).
I break in my ICEs as in the post a few weeks ago. Then after about
10 minutes of running 'hard', but not WOT or under large loads. I add
Molybdenum Sulfide to the dino oil. Then around 500 miles flush and
use synthetic (Mobil 1) and molyb additive.
Why some have asked how come my dash gauages show such high
engine oil PSI. Largely due to both my break in procedure and Molyb
A bit on the low side pictured, as it used to go past 80PSI and hang at aroung
47-50PSI at idle and in need of an oil/filter change. Plus it's at just
over 156K with some tough towing miles, so it's getting old.
Once it has plated, it doesn't ever need another treatment...except
for extreme pressure spots. Like the top of the cylinder next to
the head. It does get scraped off over time. So I re-treat every 20K-40K
or so miles...depends on which car/engine. The Z got it more often, as
am a boy racer in that more/most all times...
I only use molybdenum disulfide filled grease. Mainly high temp
disc brake grease filled with molyb. On everything. Bought a big
plastic jug, about 1 gallon, of Sta-Lube High Temp Disc brake
lube. Load my grease guns with the stuff.
Wonderful stuff for diff's (open, not for anything with a clutch) and
manual trannies. Anything with a clutch will ruin it, as it's too slippery
and the clutches will have next to no friction.
NOTE that this stuff leaves nasty, permeate grease stains on clothing...
If you find some sites, please link them here or start another thread.
-old Ben
PS...always wanted to coat the entire innards of one of my 'built'
ICE's, but never found anyone willing to do that. Tungsten Disulfide
is a 'cold' process and like said, asked Speeder to check out that
place in Tulsa. Way cool to have an ICE with almost no friction
from it's moving parts sliding on each other... Around that time, 'hard
chrome' was also touted as a friction reducer, but that is even more
expensive and harder to work. Harley had an engine hard chromed
and never heard back on how that went.
