L31Sleeper
Location: LA,CA fresh L31, Looking for a RamJet 383 w/ twin turbos
 130 mph dash ??
Hey James in one of your accel videos it looks like you have a 130mph dash ?? where did you get it.
I've only seen the stock 100 and the police tahoe 120 ??
confused
-Justin
| Fri Jun 27, 2008 7:24 pm |
99bluetahoe
Police tahoe ones are 130mph.
99-00 Denali and Escalade, 2000 Tahoe Limited had the 120 mph clusters.
| Fri Jun 27, 2008 7:27 pm |
s10mods
Location: 93 Yukon 6.0/4L80E 9" lift 4.88's 37's, 01 Grand Pirx GTP, 95 Yukon GT 6.0/80E in progress
I have the 130 IP as well, I picked it up from my local yard, I was walking threw and they had a police tahoe there, got it for $75 I modded mine to backlight red.
| Sat Jun 28, 2008 5:33 am |
Location: 97 GMC rcsb 14.8@94 2.007 60ft rads. 4000lb L35 verter 3.42G80 marine intake LT headers EWPCM
I jave a PP Tahoe cluste as well.
Hey S10 Mods, what did you have to do to get it to work properly?
| Sat Jun 28, 2008 12:58 pm |
s10mods
Just had to solder a wire to power another section, no speed sensor change or anything. checked with a gps and the speedo is correct.
| Sun Jun 29, 2008 7:43 am |
L31Sleeper
So S10 you just stumbled on one ? If anybody has a 120 or 130 hit me up !!!
| Sun Jun 29, 2008 12:28 pm |
Location: '99 Tahoe, Vortec 454, 4L80-E, GV-OD, 4.56 Eaton 14bolt
| Sun Jun 29, 2008 12:57 pm |
Location: Macon Ga., GEN-6 454,MSD IGN,4L80E, 0411, 14 BOLT,HYDRO-BOOST
L31Sleeper wrote:So S10 you just stumbled on one ? If anybody has a 120 or 130 hit me up !!!
I HOPE YOU FIND ONE. I HAVE ALSO BEEN LOOKING FOR A 130 CLUSTER FOR A WHILE NOW.
GOOD LUCK
ROBBY
| Sun Jun 29, 2008 8:38 pm |
Aloicious
Location: 96, C1500, LS31, T56, 24x CNP/LS2 coils, I/C'd Whipple, 411, EFILive, true MPFI, ZZ4, Trutrac...etc
stroker97k1500 wrote:L31Sleeper wrote:So S10 you just stumbled on one ? If anybody has a 120 or 130 hit me up !!!
GOOD LUCK
ROBBY
check out this one. technically its a 136mph sweep.
http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__NEW-99-TAHOE-INSTRUMENT-CLUSTER-ASSEMBLY_W0QQitemZ370064933493QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQadiZ2865QQcmdZViewItem?hash=item370064933493&_trksid=p3756.m14.l1318
for you metric folks its probably normal, but its just funky looking for me me to see 0-220 on a speedometer like this.
| Sun Jun 29, 2008 9:56 pm |
Aloicious
its not a police 130, but happy birthday my friend:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=016&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=260231441431&rd=1
there's also this one, but the picutre is a crappy generic photo that looks like the wrong cluster, however according to the description, it should be the correct 99-00 120mph gauge setup. might try contacting him to see if he has actual pictures of it or any info.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=290177925585&ssPageName=STRK:MEWA:IT&ih=019
this thread reminded me that I want one of these  . I just got a 120mph cluster with almost my EXACT mileage on it (when I do the swap it will be within a few hunderd miles. close enough for me)....for $50. score. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=230265797403&ssPageName=STRK:MEWN:IT&ih=013
EDIT- here's some swap info for them. apparently the 120's are direct bolt ons, no altering wireing, or adjustments. can anyone confirm this?
http://www.fullsizechevy.com/forums/general-discussion/interior-tech/131538-1995-1998-99-00-instrument-cluster-information.html
| Sun Jun 29, 2008 10:15 pm |
s10mods
yep, was walking threw and there it was. I am looking for another one now that I have my 95 yukon that I am doing the 6.0 swap in to.
| Mon Jun 30, 2008 3:08 am |
s10mods
James B. wrote:I am still hoping Dakota Digital comes up with a cluster for our trucks:
http://www.dakotadigital.com/index.cfm/page/ptype=results/Category_ID=66/home_id=59/mode=cat/cat66.htm
For some reason I have never cared for the digital gauges, I guess I dont like how they react to quick changes. I have Autometer ultra lights in two of my vehicles.
| Mon Jun 30, 2008 3:10 am |
PSWired
I'm grabbing one of those escalade clusters if no one else takes them by this afternoon. I let my last one go when I sold the black truck.
FYI it is very easy to swap your existing odometer into a new cluster in the 95-99 style.
| Mon Jun 30, 2008 5:15 am |
Aloicious
PSWired wrote:I'm grabbing one of those escalade clusters if no one else takes them by this afternoon. I let my last one go when I sold the black truck.
just swap out the actual odometer? thats a thought, does it just unbolt and bolt on to the other cluster, or is there more to it? (I'm talking about non-digital ones of course)
I'd rather have my odometer exact.
| Mon Jun 30, 2008 10:33 am |
PSWired
Aloicious wrote:PSWired wrote:I'm grabbing one of those escalade clusters if no one else takes them by this afternoon. I let my last one go when I sold the black truck.
Yes, once you pry the cluster apart (easy to do, just have to be careful) you will see the odometer module is held in with a torx screw or two. You can swap your existing one into the new cluster with very little trouble. I've done it a few times on my trucks as I moved my old Escalade cluster around.
| Mon Jun 30, 2008 11:17 am |
Its actually very easy to change the values that the odo reads. I hate buying GMT400 trucks as I dont trust the actual mileage sometimes. I look very carefully at other indicators of mileage OTHER than the odo.
An odometer that reads 300,000 miles comes out TOO easy, and in a couple minutes can read 120,000 miles or any other mileage you want. You just have to clock the appropriate numbers to read whatever mileage you want.
S10mods, I knew someone did a jumper mod, I couldnt remember who. Thanks.
| Tue Jul 01, 2008 8:11 am |
I have the 120 and its as simple as removing a couple of screws. Actually the hardest part is getting the dang dash front off and over the s-wheel! www.car-part.com has them. I searched today thinking about going with the 130. They range in price from $100-150 (now I would bargin with them as it seems steep). If you are searching its the police package with the "Z56" option and the part number is 16265075.
I'm in Denver and tomorrow I'll go over and check out the one at "chevytruckparts"
| Tue Jul 01, 2008 10:49 am |
GMCYukalade
I got my Esky cluster from car-part.com - for around $50 bux, alot cheaper than ebay any day.. - just have to search for 99 cadi escalade - and then choose speedometer (not guage cluster) - go to the page w/ the * beside it, and start calling numbers (the * represents the cheapest cluster)
| Wed Jul 02, 2008 12:35 pm |
Aloicious
GMCYukalade wrote:I got my Esky cluster from car-part.com - for around $50 bux, alot cheaper than ebay any day.. - just have to search for 99 cadi escalade - and then choose speedometer (not guage cluster) - go to the page w/ the * beside it, and start calling numbers (the * represents the cheapest cluster)
thats a good site, never been there before, they have several esky clusters for pretty cheap, they even have several police clusters around if you search 1999 tahoe and they give a police package option.
| Wed Jul 02, 2008 2:54 pm |
Aloicious
Just as an update, I put in my esky cluster a few mins ago on my break w/ blue LEd's to match my stereo (and truck for that matter) and it worked great! switched over the odo so the mileage is still correct for the truck and it looks awesome, speedo seems to be correct as well, I'll have to test it out later though.
| Sat Jul 12, 2008 1:09 am |
