Reply to topic Page 4 of 4
Goto page Previous  1, 2, 3, 4
95 GMC
Chevy 97 wrote:
Quick question concerning camshafts and computer compatible, I found a cam that I would like to have for the engine, but when you look at the specs it says not computer compatible. Do you need to use a camshaft that is computer compatible?
Some computer control systems require a certain amount of vacuum signal for the MAP sensor, and too much lope will interfere with knock sensors. Computer cams are designed to work with the computer.
I looked up the cam that is in my 383 from GM. That cam also says it isn't computer compatible. Yet they sell it in the 383 for a computer controlled truck. Comp cams looks like they have one that would be of interest. XR264 HR13
I took a few pictures of my wiring, so I would remember where things go. Some wires I put colored zip ties on to match them up. I am removing the wiring so I can park it outside when the engine is getting worked on.
This is a first for me to see, a support on the back of the tail shaft on the transfer case.
I've never seen that before either. Looks like a good thing thou.
I asked Whipped383, since he works on a lot of vehicles. He said he has seen a few of these on the 2500 trucks with the newer transfer cases. My brother in law owned this truck first, I think he ordered it in. At the time he got this truck he was working as a contractor out in the oil field. He had to travel to a lot of well sites. with the summer rains and the winter snow, plus a 454, it makes sense that this is on this vehicle. The transfer case just hangs on by 6 bolts. I wish I had this on my half ton, since I had changed to the 4L80E.
Finally got a chance to work on this, removed the driveline.
I got one torsion bar to move, the other one is being stubborn.
Sure glad these came off with out issues.
I have been a bit slow on this truck. I had to cut the exhaust pipe to get it out. Today, I got rid of the starter, the cover over TC. Drained oil. Removed filter and front skid plate. Tomorrow I may reve the transfer case. I still need to remove the top of the intake to get at fuel lines. At least engine roated to remove TQ bolts. Broke one bolt in the Cover. I hoe it was not loctited in place. Not going to be easy to remove..
I think we all have a broken bolt story or two! It sucks - takes a lot of time. Some of the ones I've removed were so aggravating I kept them as souvenirs. Good luck with it
Headers are removed.
I had to cut the exhaust because everything was welded.
Brother in law put shorties on years ago, because the cast manifolds kept cracking.
