What torque is recommended to use ARP or Edelbrock
Post What torque is recommended to use ARP or Edelbrock
Hello
Are underway with stress hone one sbc L31 and in doubt what torque to use.
Should I use ARP torque, Or should I use it As stated from the aluminum cylinder head supplier who is Edelbrock .
ARP:
Following the manufacturers recommended torque sequence tighten the nuts in three equal steps to 80 ft lbs
with ARP ULTRA-TORQUE FASTENER ASSEMBLY LUBRICANT.
Edelbrock:
aluminum cylinder head E-Tech 200 Edelbrock.
Head Bolt:
Apply 30W oil or suitable lubricant under side of bolt heads and washers. Torque to 65 ft./lbs. in three steps (40, 55,
65)
Br Gunnar
Use ARP specs with ultra lube. More precice torque value for one.
#2 The reason is to stretch the bolt in the elastic "spring" zone for proper clamping with ARP fasteners.
#3 Call ARP. they know their product better than any one.
