Whipple belt problems
So I'm having belt issues with my Whipple on my 383, 1.6l compressor with a 2 5/16" pulley. The problem i have is a squeaky belt. Squeak seems to be coming from tensioner alternator area, both are new. I had this problem years ago so I installed a gatorback belt and the problem has been gone. Well the gatorback finally wore out so I put a gates belt on and the noise returns. Does anyone have any ideas or suggestions of what I should look for?
I was looking through some serp. belt books with a buddy and there are some belts that are specifically designed for supercharger use. They were quite expensive, compared to regular serpentine belts. Maybe search through some OEM supercharged units like the 3.8 s/c and see what comes up for supercharger specific belts? IIRC the 3.8 s/c uses the same belt for the blower as well as the accessories. I'm pretty sure that the GEN 4 LS9/LSA and the GEN 5 LT4 use a separate blower belt for their TVS blowers.
There are also spray on and solid type belt dressings that may help?????
gatorback belt hehe
Done
I work in a machine shop where the metal walking surface gets coated with coolant and oil.
The antislip solution is to sand blast the surface.
So, maybe lightly sandblasting the pulleys might help the grip hopefully not eating the belt.
I have ordered another gatorback belt just waiting for it to arrive.
Haven't tried any belt dressing, I have not had good experiences with it in the past. It usually seems to make a problem worse and it is extremely hard to remove from the pulleys and makes a mess. I did try the old time trick of a bar of soap but that only quiets it momentarily.
All the 3.8 engines I have worked on ran a separate belt. I do not believe there is an application that would have anything long enough. The belt i am using is 110 inches long.
Whipped383 wrote:I have ordered another gatorback belt just waiting for it to arrive.
They were separate too, ok, my mistake.
The dressings can make a mess, esp the sprays, a little goes a long way.
110 inches helps, at least with the part number of the belt.
Post by James B. »
My Whipple pulley never lined up exactly with the rest of the serpentine system. I ended up using a spacer between the pulley and supercharger hub. Check your alignment with a long straight-edge on the crank. Wrap a belt around the crank and measure the distance between the straight-edge and the edge of the belt. Wrap the supercharger and compare that distance. I'm going to wager it doesn't match.
Post by James B. »
...continued....
I have a lot of experience with belts. It used to shread a $40 belt 2-3 times a year. The Goodyear Gatorbacks were the stretchiest and most likely to snap. Dayco PolyCogs held up the best for me. There's a Gates Greenstripe on the market now that seems popular with serpentine blower owners but I don't have any first-hand experience with them.
I'll check pulley alignment, I just assumed it wasn't an issue since I never have any wierd wear patterns on the belt. Heck the old gatorback was a couple years old but yeah it had stretched some.
I am noticing now that when I let off the throttle quickly WOT I hear a belt chirp. So definitely have some slipping
Post by James B. »
That chirp when you let off is the belt contacting the tensioner housing. Reverse-torque on the belt causes the tensioner to nearly bottom out. It is probably intentional that the belt geometry cannot fully bottom out the tensioner, because if it could the little limiting tab would easliy be snapped off by the tremendous force. The's not much you can do about it. Many years ago I had the idea of blower and alternator pulley with one-way clutches in them to prevent reverse torque on the belt. They're actually available now and I'm sure they work great, at least they did in my head 15 years ago.
James B. wrote:Many years ago I had the idea of blower and alternator pulley with one-way clutches in them to prevent reverse torque on the belt. They're actually available now and I'm sure they work great, at least they did in my head 15 years ago.
That would be sweet
