Grounds!!!
Post Grounds!!!
I am finishing up my LS Swap in my 98 and I have a ground issue. The truck starts and drives Fantastic! However my gauges are all wonky. They all bounce to the turn signal and when I turn headlights on they go down and there is a buzzing sound. I am fairly certain how things are wired that they are correct. When I was hooking the body and chassis grounds back up I for the life of me could not figure out the bare braided ground strap on the passenger side. What two points does it connect to? Can any one post a picture or two. Thanks!
I have the body (stud under heater hoses) to rear of head on the right side.
I have battery to frame
and
Battery to front of head on drivers side
Is there a Body to Frame ground I am missing and where would that be?
Let's see... passenger side goes to the frame and to the engine block. There should be a hole drilled into the top of the frame over there with marks from a large star washer, and the other side will bolt to one of the excess head bolts. Body to frame can go anywhere, and there should be no reason for the body to frame ground to be removed for an engine swap.
