Page 1 of 1
 update...A/C sensor and 4LOW does work with COS3/4l80e
for those who may have been wondering...
I just got my motor running with cos3 and with the a/c pressure sensor input for the ecm controlling the (1)efan and temp sensor on the other still works after converting to cos3.... also shifts at part throttle in 4low.
| Sun Apr 01, 2012 8:44 pm |
Sweet thats good to know
| Mon Apr 02, 2012 6:08 am |
Aloicious
good to hear!
what base tune did you use for the COS3?
| Wed Apr 04, 2012 3:05 am |
I will be asking questions on this when I put my fans on.
| Thu Apr 05, 2012 8:55 pm |
Aloicious wrote:good to hear!
I will look soon and let ya know... But the Efan nor the 4low part was originally in the base tune. The engine segment was swapped onto a 4x4 trans segment tune and the efans were turned on via tuner cat and then copied with efilive to get that part working and then converted to cos3.
Edit:
Base tune OS # 12212156
Cos#. 02020003
| Fri Apr 06, 2012 3:30 am |
A while back when the 4low shifting issue was going
On I misinterpreted the original ? The regular tune files and even cos3 will shift in 4 low BUT you have to floor it then let off.... Then it shifts... The converted file works like a normal shifting setup. I Originally was thinking guys tunes would not shift at all... But now it's clear what was going on.
| Fri Apr 06, 2012 3:40 am |
Yeah Iv had mine working with a 4l60e for a while now. I used a base tune I think s10mods put together. It was a ZR2 base tune with the e-van engine segment swapped into it. So what was used for the base tune with a 4x4 4l80e?
| Fri Apr 06, 2012 6:14 am |
Whipped383 wrote:Yeah Iv had mine working with a 4l60e for a while now. I used a base tune I think s10mods put together. It was a ZR2 base tune with the e-van engine segment swapped into it. So what was used for the base tune with a 4x4 4l80e?
I can't remember.... He did mine as well... May have been a 2500 truck tune file... Maybe he will chime in
| Fri Apr 06, 2012 5:50 pm |
If you get the base tune file from him let me know I would like to do the 4l80e swap one day. Actually I think he has it posted on the efilive forum but I didnt know if anyone had tried it or not.
| Fri Apr 06, 2012 6:56 pm |
I was running that one modified for the 454 for about a year now. If you need it, I can send you
My old tune and just change the tables to fit your setup.
| Fri Apr 06, 2012 9:29 pm |
I have the one here http://forum.efilive.com/showthread.php?7914-0411-conversion-issue/page3 on post 29 isnt that the same one were talking about?
| Sat Apr 07, 2012 7:39 am |
The 4L80E 4x4 tune I am running is different... its only been made now in the last year or so. I remember you asking a while with that one working on here....
| Mon Apr 09, 2012 6:37 pm |
Hi Rob, I have the high rev shift problem, how did you modified this tune to get it to work properly?
| Tue Apr 10, 2012 4:56 am |
Ben,
I can send you my current tune cos3 tune and you can copy your parameters over to it if you want.... But "I" personally didnt fix this issue... I believe it was S10mods that did it for me by swapping my engine segment over to a 4x4 4l80e tune file
| Tue Apr 10, 2012 8:41 pm |
The time now is Fri May 24, 2013 3:15 am | All times are GMT - 8 Hours
Page 1 of 1
