SikSilverado
 So i deleted a few things..
Like the manual fan, its in the 30s.. I have hard enough time maintaining heat lol.. No intake heater - anymore..
figure I picked up some free HP from this, I know without the intake heater it snappy on the throttle now got something like 26.7mpg today. unreal..
I'm not towing so Im not too worried and I dont sit and idle either. Maybe one of you guys might try it
| Sat Jan 07, 2012 9:15 pm |
wow, great mileage! how many miles on this one?
| Sun Jan 08, 2012 7:28 am |
SikSilverado
156620
Its running a built trans with 295 psi constant line pressure too..that takes it down efficiency a little too..
stock tune
| Sun Jan 08, 2012 7:58 am |
This is the magic of the electric fan. You get the same effect, without the worries of getting stuck in traffic and overheating.
| Sun Jan 08, 2012 10:11 am |
Speeder wrote:This is the magic of the electric fan. You get the same effect, without the worries of getting stuck in traffic and overheating.
X2
| Sun Jan 08, 2012 5:11 pm |
SikSilverado
I'm going to measure some lt1/ls1 or Taurus fans..had some lt1 fans on the 01 silverado. Money is gonna be tight for a bit.. been buying alot of parts..
| Sun Jan 08, 2012 5:29 pm |
I have a set of fans for a 2006 Silverado sitting in my garage. Bought it from Rock Auto. It is not for sale. I can try to remember to take measurements of it tonight. I'm thinking I may be able to install it this weekend.
Does anyone perchance know what specific port(s)s on the computer the fans need to be connected to so that I can run them off the PCM? I'd prefer to run them parallel so each one can be controlled individually but wouldn't have a problem with running serial if need be. Decided against trying to use a DCC unit, since their website appears to be dead now.
| Mon Jan 09, 2012 4:47 am |
SikSilverado
that'd be cool. I wonder if they are the same dimensions.. with the exception the radiator being thicker (extra core).
| Mon Jan 09, 2012 6:42 pm |
Im pretty sure the dmax rads are quite a bit wider and possibly even taller than any of the gassers but itll be interesting to know
| Mon Jan 09, 2012 6:49 pm |
Whipped383 wrote:Im pretty sure the dmax rads are quite a bit wider and possibly even taller than any of the gassers but itll be interesting to know
If you get those dimensions I would like to see those! My new truck has the belt driven fan and I would love to have electric's
| Tue Jan 10, 2012 5:21 am |
Fan dimensions:
Bottom mounts are 2 inches wide
Outside to outside bottom mounts 32 inches
Tallest point bottom to top 21 inches
Widest point 38 inches
Top mount distance range 31.5 inches to 33.2 inches
Radiator draw area 17.6 inches to 33.75 inches
Deepest point radiator to engine 6.5 inches
Deepest point at the motor 5.75 inches
Deepest point in the center where the water pump drive is 4.6 inches
The whole assembly
Upper mounts slide in,
and out.
A shot of the power plug, which can be ordered separately.
Passenger side
Driver side
Lower mounts are fixed
This shot shows the tallest point on the radiator, which is some sort of support. It can be cut off if needed.
Fan motor
| Tue Jan 10, 2012 2:22 pm |
SikSilverado
I'll measure mine friday when I have time.
There is no way I didn't pick up 30hp.. Didn't make much of a difference on my 4.8L but on this rig.. its very very obvious. I can peel out accelerating down the freeway @ 65+.. stock tune. weird.
I also tested things... stopped traffic = never went over 190.
temp 31 - 42 degrees.
5% incline 1000 deg EGTs.. 10+ min.. never passed 188.... 40mph.
Actually seems to have made the thermos pretend to work right too.. When I installed the new ones from Oreilly, theyd go from just above the 2nd line to just before middle bar (210) gauge would show 184 >> 188. 4 degrees and the gauge looks like there is more going on. Now without the fan, the bouncing seems to have mellowed out. very odd.
| Wed Jan 11, 2012 9:30 pm |
Sik, sounds like your old clutch fan may have been siezing up then. It's supposed to freewheel until the system gets hot enough to heat the spring on the front of the clutch, which will then lock the fan on. If the fan was staying locked on, then the engine would be kept cooler than it was supposed to be while robbing engine power for no good reason. I'd planned on putting mine on today, but Mother Nature decided otherwise. We got an inch or two of snow last night and it's still in the 20s as of this posting. I don't work outside in these conditions unless something is broken hard.
| Thu Jan 12, 2012 7:49 am |
Speeder wrote:........ I don't work outside in these conditions unless something is broken hard....
Roger That! Plus 1.
| Thu Jan 12, 2012 12:59 pm |
SikSilverado
yeah it was 30s today. going to snow sunday - > Weds..so I'll wait
Was going to put on the stainless braided brake lines today too.. oh well.
Fan wasn't roaring or anything. I think it was ok, it does spin freely by hand.
| Fri Jan 13, 2012 5:24 pm |
SikSilverado
So I'm back in Arizona. Drove with a 5th wheel from Portland to Phoenix. NO FAN. Never once got too hot. Although unhitched I'm getting 26mpg .. How I have no idea. . Must be the "dry"
Summers coming, so I gotta get to measuring soon on those electric fans!
| Tue Feb 21, 2012 11:32 am |
playtoy_18
A single 15" or 16" fan will cool a 350,how I did it on both my Yukons.
I yank taurus and camaro fans,run about $30 at the yard.
| Wed Feb 22, 2012 2:36 am |
Did you get the pinouts Ed....or still need them?
| Wed Feb 22, 2012 3:02 am |
playtoy_18
I'm assuming sik is Ed also,lol.
i've got pinouts and instructions for pcm fan control,i can't post up though.
Damn Dell crapped a hard drive on me last week.
Gotta do damage control and repair.
| Wed Feb 22, 2012 4:28 am |
Lol! Sorry Ed.....I meant 'Jim'.
| Wed Feb 22, 2012 4:50 am |
