Page 1 of 1
 Oil leak
2000 Silverado, 4.8L, recent rebuild
Danged thing has a pressure oil leak that I can't seem to find. I'm starting to think that I might have a ring problem, but I can't pull the engine down right now to check into it because the truck is the only thing I have to drive right now. Changing the PCV from the older rattle type to the newer fixed orifice with a smaller hole makes the problem worse. So I'm thinking... what effect would pulling the PCV valve out altogether and replacing it with an old style filter fix my problem until I can get another car and get this dealt with? If I drive it easy it doesn't leak, but if I get into it it'll build pressure and start blowing oil out.
| Thu Dec 22, 2011 8:23 pm |
I'm also stuck with oil leaks.
I know were they are comming from (oil dye). I can't get them to stop.
I'm considering using a vacuum pump...
It's got new seals everywere, rtv like crazy but no joy.
The parts guy says the new felpro oil pan gaskets shoud be installed with no rtv.
| Thu Dec 22, 2011 9:11 pm |
Speed didnt you have this problem before and end up fighting the dealer about it?
| Fri Dec 23, 2011 9:45 am |
It builds crankcase pressure with higher load. That has to mean rings.
| Fri Dec 23, 2011 9:57 am |
Mine leaks from idle.
| Fri Dec 23, 2011 3:00 pm |
Yes, that dealer put on an oil pan gasket then said I needed a crate engine. No troubleshooting at all.
Sucks, I'm also thinking rings, and both my dad and brother are saying the same.
I picked up a couple of crankcase filters today to see if this will help. Worse comes to worse, I'll pick up another engine and slap it in. If I can find something else to drive before it hits the fan I'll pull this one down and fix the problem.
| Fri Dec 23, 2011 8:12 pm |
Speeder wrote:Yes, that dealer put on an oil pan gasket then said I needed a crate engine. No troubleshooting at all.
You can buy a leakdown tester and see if the rings are sealing properly or if the cylinder is ok or not.
I would bet if its the rings then either the wrong rings or end gap, cylinder was not honed properly/and or the honing grit was not properly cleaned from the cylinder bores' cross hatch scratches. this is where a lot of builds are cut short from shops
| Fri Dec 23, 2011 10:24 pm |
Did you by chance use chrome-moly rings?
| Sat Dec 24, 2011 8:28 am |
Not sure on the rings. They were part of a kit. The guy that did the rebuild also does rebuild work for the local Chevy dealer.
Pulled the PCV out today, the updated version has a pinhole, no rattler inside. It's a hollow body. The hole is far smaller than the old one, and the leaking got worse, so it's definitely a pressurization issue. I've plugged the intake and throttle body part of the venting system and installed filter breathers on both valve covers.
Also did a cylinder pressure check, pressures vary from 150PSI to 180PSI for a 20 percent span difference. Not happy about that. If the filters stop the leaks, I'm going to stop messing with it. I've already started putting back money for a new engine, again. This time, just going to get a crate engine from the dealer. Wish I'd have gone that way to begin with, as I could have bought a crate engine, high performance heads, and the cam of my choice for less money and not had these problems.
| Tue Dec 27, 2011 2:35 pm |
The time now is Tue Jun 18, 2013 3:32 pm | All times are GMT - 8 Hours
Page 1 of 1
