Thunder... turbo questions
Post Thunder... turbo questions
A long while back you made mention that you could duplicate the STS turbo setup. While perusing turbo links related to my ill-fated turbo-driven accessory idea, I came across a few 4.8L turbo applications where they were putting down 500+HP, which is more than what I'm intending for the next engine in the 'ol lady's Silverado. Now I'm still leaning towards an NA 6.0 or 6.2 right now, but seeing those kinds of numbers from a 4.8L peaked my interest a bit. I'm not saying I'll go turbo on this, just that right now I could be convinced. Very Happy
If I were to do this I would want the remote mounted single turbo, and would still be aiming at 450HP or so at the flywheel. I'd also still be looking at a 6000RPM redline. Normal cruising RPMs are around 1800 to 2200RPM depending on cruise speed. Torque converter will remain stock stall.
The questions I have are:
Exactly how would a turbo V8 act in day to day driving?
What sort of fuel economy would I be able to expect during normal driving? I know you can't give me an exact number, but a rough comparison to a similar NA application would work. Perhaps the difference before and after on the 305 you did.
How would it handle towing for distance, like more than an hour nonstop?
What all would I need, and what could I expect the price to be, ballpark?
I'm not too familiar with how turbos react in day to day circumstances, but a turbo that can put down 500HP should be a load of fun to drive WOT. The 'ol lady's wanting me to get the truck up to at least 20MPG, although I'm not quite as concerned about that as she is these days.
Did some checking into this on the Garrett turbo site. Looks like for a 4.8L, looking for power from 2000 to 6000RPM, I'd be looking at a GT2540R unit. This is likely the unit to be used right off the engine though, and not back under the bed where the unit would go. When I went through the formulation, I came up with:
2000RPM 21.26, 1.55
6000RPM 25.56, 1.86
Still not sure if I would want to go this way or not, since it would be a much more complicated setup than a larger displacement engine would be.
the X factor in duplicating the STS system is the oil - turn the way back machine to when i was prototyping my chevelle for the truck, that was the concern i was having and was doing some digging on how to create a stand alone oil system...about a year or so later STS was born and had the universal kit with the same oil pump i was looking at using, but the still used the same oil used in the engine...
long story short, yup, i can duplicate....
lemme try to address each question...
1 - Exactly how would a turbo V8 act in day to day driving?
well, i guess it depends on the driver, but from what experiences i have had, it acts just like it did before the turbo with a bit of a kick when you want it. in some cases it acts like a bigger motor - imagine uphill at part throttle, it will get into boost a bit and climb the hill faster at the same throttle position. it will be easier to pass and you will actually
find yourself using less of the throttle because you have more power on tap...
2 - What sort of fuel economy would I be able to expect during normal driving?
again, it depends on driving style, how much city/highway, but in my truck (for example) i actually saw an increase in mileage - not much, and i didnt really have enough time with the turbos to verify all the info, but i did get better, and even better when i switched to E85 - which goes against what everybody says.... there was 1 tank i remember getting an extra 75 miles from E85 compared to straight gas. again, i didnt have enough time to get solid numbers, but overall turbos got me slightly better mileage and i did not change my driving style so i am confident in saying that you could see 1-3mpg improvement and worse case stay the same, the only way it could go down is if you get too happy with the new found power and cant keep your foot out of it, or go on a towing spree...
3 - How would it handle towing for distance, like more than an hour nonstop?
with a remote mount system, thats actually better for towing than an under hood system. remote mount is all by its lonesome under the bed with plenty of air movement to help with keeping things cool - not that you really want that as velocity goes up with heat and expansion, but in a towing environment, with constant demand - the turbo would be working all the time and you would need good manifolds if underhood to prevent cracking - but with the remote mount, temps stay under control.
a did a bit of towing, for more than 1 hour and even in the engine bay, they did not overheat, but did get hot - to the point where i was looking at maybe some GNX style side vents to let the heat out. but, remote mount, you dont have to worry so much about the heat issues or protecting parts and is actually less money in the long run.
i dont think there is a towing issue with the remote mount systems.
4 - What all would I need, and what could I expect the price to be, ballpark?
thats a big question and has many answers depending on sources and the like...
as far as what you need, heres the basics of what i would get to have a reliable system..
1 - turbo (of course) - this is the biggest expense and the most critical choice here. i dont have my compressor maps handy - they are all on my hard drive at home, but i would be looking at something in the T4 class and larger. you dont NEED a ball bearing turbo, but price and efficiency go up with one.
2 - intercooler - this is where bigger is usually better. you would want the largest you could fit. the sole purpose of the heat exchanger is to get your charge air temps as close to ambient as possible. this is where you either get creative or shell out the money, you can take several cores and weld them together (quite common) or find something that fits from some type of diesel setup (also common) or you best out the tape measure and get either a universal core with end caps, a universal intercooler, or have one custom made..
i had a diesel intercooler i was playing with (but i discovered how hard it is to modify) , i ended up with an ebay special - i think it was one of those 24/12/3???? anyway, i spent roughly 150 on it, all my tubing was exhaust pipe which saved a lot of money compared to the "custom" crap i could find. i ordered my mandrel "U" bends from JCWhitney as well as the straight pipe and went to town with a chop saw....
3 - you would need an oil system for the turbo. the easiest way is to do how STS did and tap into engine oil supply. the oil pump information is also on my other drive, i want to say it was in the 2-300 dollar range (been too long since i looked). it was the exact same one STS uses with out the label. has a very good life expectancy. the other option would be a stand alone oil system, which would add to the cost but in my eyes better for the engine and turbo itself as the turbo would not see the dirty oil from the engine and vise versa. with that system you would need a tank that holds about 1 gallon of oil (because its easy to get anywhere and simplifies oil change as well as adequate capacity) i would recommend 3 oil pumps (redundancy as well as a pusher pump), you would need a cooler - i would think a typical oil cooler with a fan would fit the bill, and your gauges and pressure sensor - BUT - see how this starts to get complicated? yes, there are benefits, but it starts to make things more complicated and no so street friendly.....
stick to using the engine oil and you will be fine.
BOTTOM LINE - you could put this system together for roughly the cost of a used supercharger if you shop thrifty, but the reality is most likely in the 2-3k range. i was lucky with mine, my first setup i did for less than 500 bucks, most in part to a lot of used stuff that did not have much life left in it, or any where near proper for what i wanted - but it worked well enough to get me hooked on turbos, and when i mashed the pedal and lost sight of the road because my hood became the horizon....well, the rest, they say, is history....
now, the nice thing about the remote mount system, you can still have headers and a cam - and contrary to what people say - with the remote mount, you dont have to be so picky as to cam choice, you can actually go with a SC cam and get excellent results. the turbo cam profiles are based on close mounted turbos where the exhaust back pressure is so high that it will force its way back in through the open valve - with the remote, you have less pressure because of the added volume of pipe.
so, you can still keep the things you have for it, which in turn will help it - not only on the performance end, but in the mileage department as well...
20mpg is a highway number - and if i can do it on 32's or whatever those tall tires i had were, with 4.10s, and 75mph - it is possible, but is a highway number. i was averaging 16 before turbos and almost 18 after, and a SOLID 18 with E85 (which still baffles the hell outta me)...oh - and i had more psi as well i saw 12psi spikes, but it was a steady 10psi if memory serves, my fuel system was maxed out, im sure, but the 4.8 as wiggle room my 305 never had.....i would also like to note - my 305 liked more timing than my 350 - never did get a chance to play with that theory as the oil pump went in the 305 - but i still believe the 305 with the smaller chambers is less likely to be prone to detonation than the 350 - my only proof is the fact that i was running 10psi with a wicked advance curve on cat piss gas with no knock - remove turbos, swap in 350 with same tune and knocked on 93 octane.......had to pull 10* of timing to get the 350 to act right, never did get a chance to run the turbos on that motor.....
all this info is just that - info. can be modified on all points and argued to death (which i welcome, thats how i learned the stuff i know)
if anybody would like to add, please do - i know JamesB has been doing some research on turbos and his info is pretty fresh in his brain - would be great to see some other responses and theories - or facts, whatever.
i know Lextech has a lot of practical application information, including frame twisting Laughing
ok, im done with my book....
View user's profile Send private message Send e-mail Yahoo Messenger
oops, forgot to add boost referenced FPR - kinda need that....
Cool. This is gonna take some thought then. Right now I have the Pacesetter ceramic coated long tube headers and a set of the Magnaflow high flow cats ready to go on. I'd definitely hate to have to give them up. Hmmm... think think think...
Considering that I'm not going for a huge, high RPM racing engine, would a stock 4.8L do the trick or would I need to do lower compression pistons? The 4.8s are around 9 to 1 depending on year. And how well would a turbo-optimized cam do on a non-turbo engine? My thinking here is possibly doing this as a 2 part project, do the engine first then the turbo setup second.
All else equal, smaller bore diameters have greater detonation resistance.
If I ran a rearmount, I would be more apt to run manifolds on my GMT400. If I had a GMT800 truck, I would probably just run the stock manifolds.
Size the turbo appropriately, and along with your stock TC response would be decent.
I think you could get 450-500 gross engine dyno hp without much trouble on a 4.8. In all honesty I would bet money your wife would have all sorts of fun with a rear mount turbo and a bone stock 4.8.
the 4.8 is the "peakiest" of all the GEN 3 SBC's. It has the same air intake/t-body/MAF/intake manifold as the 5.3 and 6.0, and slightly different cam and bit better heads on the 6.0.
When people compare the 4.8 and 5.3 they always remark that the 4.8 is "peakier" than the 5.3 because of its short stroke. I tend to believe this differnce is more because of the same parts being used on a smaller displacement engine.
It all depends on what your goals are. In your truck a turbo 4.8 with 500hp capability will have better fuel economy than a 6.0 that has that same 500hp capability.
A stock LQ9 6.0 on an engine dyno with headers and agressive PCM tuning will output just under 400hp, an LQ4 in the same scenario will output about 5hp less than the LQ9 due to the 0.6:1 compression difference between the 2. To get your extra 50-100hp will need a camshaft change which will hurt mileage, and may more power peaks up towards your build imposed 6000rpm redline. Proper acceleration benefitting shiftpoints will probably be above 6000rpm. Turbo will have a stock rev range, maybe 100-300 rpm less than stock.
Any increase in volume after the turbo that you add between the turbo and the intake valve creates more space that needs to be filled before boost can be created. For short WOT blasts the tubing can act as a small I/C but for towing, you will need an I/C to reduce IAT's. Just keep in mind the volume of anything you add.
The good thing is that you have access to a PCM tuning program. You can find a starter tune somewhere, then tweak if you wish. Or if you have to, you can get a Pro-Tuner to email you a tune, or get some dyno/road tuning done.
Turbo will be a more complicated tune than a N/A engine.
If you do the turbo 4.8, you can always throw a 6.0 in there.
I really dont know as it's your truck, but there certainly are lots of things to consider. Just curious, is the 450-500hp for you or your wife?
well, my 305 was stock, and stood up to 10psi in a not so friendly manner Evil or Very Mad
but i would never discourage building an engine in any way - but i thought the 4.8's had forged pistons, or am i wrong on that one? i thought that was the piston slap issue??
a turbo optimized cam i think is more a matter of perception, what your looking for is LSA of about 114 or better - i believe the stock LS7 cam has a LSA of 116 and would make the perfect low budget turbo cam as was used in the 5.3 that was thrown into the ford that 1320video built that went 9's on a stock 5.3 - the cam being the only mod to the engine.
with the remote mount you can still use the headers and high flow cats - thats the beauty of the remote mount. not only do you get the added power from the turbo, but you get the added power and efficiency of the headers and cats which in turn helps power end efficiency of the turbo - its a win/win, and the purpose why i was doing the research way back when and also the system i will be doing with the 454 - although it will be a little less utilitarian as i will be using the space in the bed, but my purpose will be to have a pretty fast truck that looks completely stock when you open the hood.
as much as i like to go fast, i also like to do it repeatedly and reliably, which is where i stand when i make any suggestions. i like to leave over the top for more strip oriented vehicles. i see no reason why a turbo 4.8 cant do a 12 second 1/4 and still get good mileage out on the highway and still be treated like a truck.
I didn't know on the pistons, so I looked it up. I do know that the piston slap issue is a result of the piston skirts being made too short, causing the pistons to rock in the bores until they expanded. Longer skirts would have solved the issue, but GM went with coatings.
Pistons
The LS9 is the only production LS engine with forged aluminum pistons; all the other use hypereutectic (cast) aluminum alloy pistons - varied mostly by diameter to accommodate various bore sizes. LS cast pistons shouldn't be used on applications greater than approximately 550 horsepower. Also, the LS7 piston's inner bracing requires the use of the matching LS7 connecting rod.
I also found that the 5.3L uses a dished piston where the 4.8L uses a flat top. A set of 5.3 pistons would lower engine compression a bit, but might also require shorter rods, I'd have to check in on that. But, if a remote turbo unit were able to make boost from 2000 to 6000RPM off the factory flat-tops, I'd be happy.
I dunno, still need to give this some thought. I'll probably still go with the larger engine over the turbo setup on the wife's truck. But, I'd not have an issue at all with doing a second truck with a turbo setup later on down the road.
http://www.youtube.com/watch?v=V9nRm6vZl_I
Stock 6.2L Caddy LSA cam has 198º/216º dur@0.050" .480"/.480"(1.7:1 rockers) 120.5ºLSA 556hp@ lb/ft@rpm
Stock 6.2 ZR1 Vette cam has 211º/230º dur.@0.050"0.562"/0.558" 122.5ºLSA. 638hp@/604lb@rpm
LS7 7.0 ZO6 Vette 210º/230º dur.@0.050" 0.593"0.589" LSA for this cam is weird, I have spuces that state 116º-121º. I do know that the LS7 and LS9 cams are pretty close, which is surprising as they are quite different engines.
Was there an outcome on this?
Yeah Speed get a damn turbo already! I can back everthing thunder is saying about highway milage going up and being reliable for towing with my whipple. I now get 17 highway and with the stock 350 only got 14 and I tow 7k quite often. Towing milage? about 9 you will loose milage there but again stock was only 10 towing so the extra power is worth it. I also live in utah so lots of hills and grades to be boosting on.
I love that. I am collecting parts for a turbo system and if i can finish all my other projects i have a 4.8 that i would like to see 5-600 hp out of.
Hey, Speeeeederrrrrrrr.....
http://www.youtube.com/watch?v=30bDLjzb020&feature=related
http://www.youtube.com/watch?v=HpSOxeKoW5M&feature=related
http://www.youtube.com/watch?v=odPGYg7FNow&feature=related
http://www.youtube.com/watch?NR=1&feature=fvwp&v=QEq3J5OcDAM
Nice, really nice.
