Nytmarek5 wrote:
Is that from the Offroad unlimited baja suburban build? The info looks very familiar that's why I ask. As far as I've seen Raylar? I have heard is the only one to do anything for aftermaret heads. My main point with the "cam and tune" is all the 6.0 guys claim better fuel efficiency factory mpg goes out the window when you start changing fuel mapping and cam and ignition timing... And it's very dependent on driving style. Although I will throw it out there that with a tune you can make an engine more efficient but generally not if you are shooting towards peak performance... The whole reason performance lacks from the factory is because they are shooting for the best balance between power, efficiency and reliability (in theory).
The one thing that does suck about finding them with a complete harness and ECM is that generally you have to send the ECM put to get flashed anyway to get rid of the VATS system and the torque management thats programmed in them.
Some of the 8.1 info I listed was from the 2002 GM Performance Parts catalogue which lists the HP3 Vortec 8100 as a crate engine which was to be released in 2003. It was rated at 525+hp@5400rpm and 560 lb/ft torque@4000rpm.
The company I was talking about is NOT Raylar, Raylar makes aftermarket heads. The HP3 Vortec 8100 used stock iron heads that were ported by the U.S. company. This company CNC ported about 60 sets for GM Performance PArts so that GMPP could do in house testing as well as supply a 9 American Power Boat Association (APBA) race teams with 8.1 engine parts. Race teams which use dteh HP3 8100 were members of "Team Vortec". These race teams competed in 2002 and the HP3 Vortec engines broke 2 world records The UTZ Quality Foods/Castaway powerboat in the Super Vee Light Twin class posted a speed of 106.167mph and the Vortec Team Extreme (Kava Kava/Air Jamaica) powerboat in the Super Vee Light Single class reached a speed of 89.672 mph.
GMPP 8100 Marine Crate Engines come from GM in these flavours:
HP1 390hp
HP2 420hp
HP3 525hp-stillborn
Unfortunatley the HP3 was never released to the public through the GM dealership/GMPP parts counters.
Here is a copy of the GMPP specs on the HP3 crate engine
2003 Vortec HP3 8100 High Performance Crate Engine
Specifications
Type: 8.1L V8
Displacement: 8127 cc (496 cu.in.)
Compression ratio: 9.1:1
Valve Config.: Pushrod actuated overhead canted valves ( 2 valves per cylinder )
Valve Lifters: Hydraulic roller
Firing Order: 1-8-7-2-6-5-4-3
Bore & Stroke: 107.95 x 111.00mm (4.25 x 4.37 in.)
Main Bearing Caps: 4-bolt cast iron
Balance Method: Internal engine balance
Intake Manifold: Factory-installed PFI (equal length runner) manifold
Oil Pan Capacity: 8 qt . (7 quart fill level after system charge)
Fuel Type: Gasoline (unleaded)(87 octane)
Fuel System: Port fuel injection
Horsepower: 525HP @ 5400 RPM
Torque: ( lb-ft ) : 560 lb-ft @ 4000 RPM
Engine Rotation: Clockwise (facing front of engine)
Spark Plugs: Platinum (1.5-mm gap )
Emissions Controls: Internal PCV orifice system
Paint Protection: Component painted
Shipping Weight: 734.14 lb (333 kg)
Materials
Block: Cast iron
Cylinder Head: Cast iron
Intake Manifold: Coated cast aluminum
Main Bearing Caps: Cast nodular iron
Crankshaft: Cast nodular iron
Camshaft: Steel
Connecting Rods: Forged steel (1141SAE shot-peened and magnafluxed with 9mm diameter bolts)
Pistons: Hypereutectic coated cast aluminum
Manufacturing
Assembly Site: Tonawanda, New York
PCM tuning is easily attained nowadays, many of us members of the PPE truck site family have the ability to do our own tuning. I use Tunercats 2 personally as do others here, but EFILive is more popular.
VATS disabling is a click of a mouse. Depending on which transmission was being used and in what application would dictate how much torque management (TM) I took away or added.
The 8.1 truck applications have very mild PCM tuning. There is lots of power left on the table. On some of the 4500+ trucks 60rwhp can be had. The gains in the 2500HD/3500 trucks are a bit lower, but 40rwhp gains are common from PCM tuning alone. So long as A/F ratios and ignition timing are not causing excessive combustion temps or detonation actual engine longevity wont be compromised. I cant say the same for anything behind the flexplate however lol.
I dont think that any 6.0 that has been cammed and modified to make substantial power gains would get better fuel economy than a stock setup. I would find claims like that highly suspect. I agree with you as well, fuel economy is directly related to driving style. IMO fuel economy really isnt a huge concern in performance builds, esp. when discussing 454/502's and 8.1's.
Its too bad the GM is no longer building the 8.1 after 2010 in any capacity. It appears that GM Marine is going with the blown 6.2l GEN 3 SBC as well as the good old 454/502.
Marine LSA 6.2l 530hp@5400rpm/545 lb/ft torque@4000rpm.
http://www.gm.com/experience/technology/gmpowertrain/engines/specialized/marine/2010_6200_LSA_Marine.pdf
