Reply to topic Page 4 of 4
Goto page Previous  1, 2, 3, 4
95 GMC
Chevy 97 wrote:
Quick question concerning camshafts and computer compatible, I found a cam that I would like to have for the engine, but when you look at the specs it says not computer compatible. Do you need to use a camshaft that is computer compatible?
Some computer control systems require a certain amount of vacuum signal for the MAP sensor, and too much lope will interfere with knock sensors. Computer cams are designed to work with the computer.
I looked up the cam that is in my 383 from GM. That cam also says it isn't computer compatible. Yet they sell it in the 383 for a computer controlled truck. Comp cams looks like they have one that would be of interest. XR264 HR13
I took a few pictures of my wiring, so I would remember where things go. Some wires I put colored zip ties on to match them up. I am removing the wiring so I can park it outside when the engine is getting worked on.
This is a first for me to see, a support on the back of the tail shaft on the transfer case.
I've never seen that before either. Looks like a good thing thou.
I asked Whipped383, since he works on a lot of vehicles. He said he has seen a few of these on the 2500 trucks with the newer transfer cases. My brother in law owned this truck first, I think he ordered it in. At the time he got this truck he was working as a contractor out in the oil field. He had to travel to a lot of well sites. with the summer rains and the winter snow, plus a 454, it makes sense that this is on this vehicle. The transfer case just hangs on by 6 bolts. I wish I had this on my half ton, since I had changed to the 4L80E.
Finally got a chance to work on this, removed the driveline.
I got one torsion bar to move, the other one is being stubborn.
Sure glad these came off with out issues.
I have been a bit slow on this truck. I had to cut the exhaust pipe to get it out. Today, I got rid of the starter, the cover over TC. Drained oil. Removed filter and front skid plate. Tomorrow I may reve the transfer case. I still need to remove the top of the intake to get at fuel lines. At least engine roated to remove TQ bolts. Broke one bolt in the Cover. I hoe it was not loctited in place. Not going to be easy to remove..
I think we all have a broken bolt story or two! It sucks - takes a lot of time. Some of the ones I've removed were so aggravating I kept them as souvenirs. Good luck with it
Headers are removed.
I had to cut the exhaust because everything was welded.
Brother in law put shorties on years ago, because the cast manifolds kept cracking.
Wiring harness out of the way, distributor out, and the top intake is of.
Transfer Case is off.
I am not to the point of pulling the engine and transmission together.
What's with the photo bucket watermarks on these pictures?
