Old Floor Jack Rebuild
Post Old Floor Jack Rebuild
So, I'm rebuilding my old Sears floor jack from the early 1970's. It's the old metallic green color and has served me well. I need to replace the seals and such - not a big deal, should be kinda fun. However, I had to use the blue wrench to get one of the rusted on nuts off. I have no idea what the grade of nut it was as it was not marked nor is the bolt it was on. I will post pics later to show where the nut was located.
The question is whether or not the nut was ever heat treated and whether or not I should re-harden the steel of the removed nut. I had to get it cherry red in order to get it off, so I'm pretty sure the nut has lost it's heat treatment.
I will most likely replace it, but this question came to mind so I thought to ask here since you guys do way more welding than I do.
