TBIâ„¢ has misfire
Anything off-topic
Pro
TBIâ„¢ has misfire
Post by Pro »
this is sad
TBIâ„¢ never misses anything
That's not a miss, TBIâ„¢ is causing time skips for TBIâ„¢'s amusement.
Post by James B. »
You are hardly ever driven by it anymore, change its plugs and put fresh gas and filter within
Pro
Post by Pro »
Speeder wrote:That's not a miss, TBIâ„¢ is causing time skips for TBIâ„¢'s amusement.
but explain radio sound good and i feel the stroke
Pro wrote:
Speeder wrote:That's not a miss, TBI™™ is causing time skips for TBI™™'s amusement.
It's all relative, time slows down for you, but since the radio is going at the same speed, you don't perceive the warpage.
What you're experiencing are tachyon burst from TBIâ„¢
CrazyHoe wrote:
Pro wrote:
Speeder wrote:That's not a miss, TBI™™™ is causing time skips for TBI™™™'s amusement.
Never noticed that TBIâ„¢ TM itself the more TBIâ„¢ is quoted
saturnstyl
Post by saturnstyl »
Because it chooses to.
Pro
Post by Pro »
Not sure if TBIâ„¢ chose TM or TM chose TBIâ„¢
Pro
Post by Pro »
2 pints low on atf
thermostat gasket broken, gallon less on fluid
fixed both
drove around
it misses for a minute every 5 minutes or so
last time i drives what when to get inspection and put bottle of random stuff in tank in order to pass
maybe thats it
who knowz
saturnstyl
What does the oscilloscope have to say?
Forget the oscilloscope, have the horse taste it to see what's wrong.
Pro
Post by Pro »
ahh yes the horsies deserve drink the petrol
