Moderators: Eric@PPE , James B. , flyingpolarbear , Dev
IMWACK
Posts: 52 Joined: Wed Jun 19, 2013 1:12 pm
by IMWACK » Wed Jul 17, 2013 2:53 pm
what rear end is in my 1998 Tahoe 2-door? also without jacking it up, is there a code on the diff tag, or somewhere else that will tell me if it is a limited slip? was limited slip even an option on this rig?
Posts: 10777 Joined: Fri Apr 30, 1999 9:12 pm
by Speeder » Wed Jul 17, 2013 4:22 pm
It'll be a 10 bolt. The G codes will tell you what the rear end is, and whether it has a posi. G80 is the posi code.
Posts: 6228 Joined: Tue Feb 19, 2008 8:30 am
by CrazyHoe » Wed Jul 17, 2013 5:59 pm
I have a 2dr and it's a 10 bolt G80 3.42
Also came with a 3.73
by Speeder » Wed Jul 17, 2013 6:41 pm
CrazyHoe wrote: I have a 2dr and it's a 10 bolt G80 3.42
That must be noisy.
by CrazyHoe » Wed Jul 17, 2013 7:41 pm
Only when the loud pedal is pressed.
by Speeder » Thu Jul 18, 2013 4:36 pm
by CrazyHoe » Thu Jul 18, 2013 8:05 pm
The 2dr Tahoe came with 3.42
or 3.72
by Speeder » Fri Jul 19, 2013 10:38 am
I know, but they way you wrote it, was like you had both in yours at the same time.
daddy_dandy
Posts: 1944 Joined: Tue Apr 08, 2008 11:56 am
by daddy_dandy » Fri Jul 19, 2013 11:09 am
one in the front, one in the back
Posts: 1016 Joined: Tue May 08, 2007 12:45 pm
by z71gmc06 » Fri Jul 19, 2013 11:49 am
Haven't you ever heard of a 2 speed rear end?
IMWACK
by IMWACK » Fri Jul 19, 2013 12:13 pm
so if the diff tag has a "G80" on it, it is L/S?
by Speeder » Fri Jul 19, 2013 1:37 pm
IMWACK wrote: so if the diff tag has a "G80" on it, it is L/S?
Yes, it is the GM factory limited slip, which works OK for most people but won't stand up to much power. And, if you have a lot of power and it hooks hard enough to break, the shockwave up the driveshaft will kill a 4L60E trans.
by CrazyHoe » Fri Jul 19, 2013 8:21 pm
Speeder wrote: I know, but they way you wrote it, was like you had both in yours at the same time.
Yes, it was they optional hybrid axle with a spare G80 that came with the auto-scrap 5 button switch....
IMWACK
by IMWACK » Mon Jul 22, 2013 10:15 am
the whole diff tag is broken off, just the little part around the bolt is still there. I guess I need to get off my butt and jack it up, put it in neutral, spin one tire and see if the other turns the same direction (L/S), or the opposite direction (open)
SikSilverado
Posts: 1858 Joined: Wed Apr 06, 2005 12:52 pm
by SikSilverado » Mon Jul 22, 2013 5:37 pm
I just jack one side up and get in the truck and see if I can drive off the stand. .
My G80 held up to 600+ hp for 185k then started to click click click click if you got on it hard from a stop.. It's a trutrac now.
